Time Before: 0.02404 seconds
Time After: 0.03377 seconds
Time Taken: 0.00973 seconds
Time Before: 0.03386 seconds
Time After: 0.03434 seconds
Time Before: 0.03462 seconds
Time After: 0.03476 seconds
Time Before: 0.03550 seconds
Time After: 0.03865 seconds
Time Taken: 0.00315 seconds
Time Before: 0.03482 seconds
Time After: 0.04258 seconds
Time Taken: 0.00776 seconds
Time Before: 0.05092 seconds
Time After: 0.05170 seconds
Time Taken: 0.00079 seconds
Time Before: 0.05350 seconds
Time After: 0.05494 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05024 seconds
Time After: 0.05519 seconds
Time Taken: 0.00495 seconds
Memory After: 2,261.703 KB
Time Before: 0.09632 seconds
Time After: 0.09647 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11822 seconds
Time After: 0.11955 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12945 seconds
Time After: 0.12964 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.13290 seconds
Time After: 0.13442 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100341' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15498 seconds
Time After: 0.15519 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
