Time Before: 0.00210 seconds
Time After: 0.00276 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00287 seconds
Time After: 0.00335 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00358 seconds
Time After: 0.00374 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00447 seconds
Time After: 0.00705 seconds
Time Taken: 0.00258 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00382 seconds
Time After: 0.01045 seconds
Time Taken: 0.00663 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01308 seconds
Time After: 0.01352 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01613 seconds
Time After: 0.01734 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01216 seconds
Time After: 0.01751 seconds
Time Taken: 0.00535 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02250 seconds
Time After: 0.02280 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02485 seconds
Time After: 0.02611 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.02906 seconds
Time After: 0.02922 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03118 seconds
Time After: 0.03262 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100356' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04586 seconds
Time After: 0.04616 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
