Time Before: 0.00672 seconds
Time After: 0.01073 seconds
Time Taken: 0.00401 seconds
Time Before: 0.01087 seconds
Time After: 0.01134 seconds
Time Before: 0.01165 seconds
Time After: 0.01182 seconds
Time Before: 0.01263 seconds
Time After: 0.01521 seconds
Time Taken: 0.00258 seconds
Time Before: 0.01190 seconds
Time After: 0.01981 seconds
Time Taken: 0.00791 seconds
Time Before: 0.02474 seconds
Time After: 0.02515 seconds
Time Before: 0.02792 seconds
Time After: 0.02918 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02403 seconds
Time After: 0.02942 seconds
Time Taken: 0.00539 seconds
Memory After: 2,261.820 KB
Time Before: 0.04403 seconds
Time After: 0.04420 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05526 seconds
Time After: 0.05657 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.059264898300171
Time Before: 0.06420 seconds
Time After: 0.06441 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06651 seconds
Time After: 0.06799 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788958034, location = '/forums/private.php?do=newpm&explain=1&u=100359'
Time Before: 0.08519 seconds
Time After: 0.08544 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.084174871444702 seconds with 9 queries, spending 0.0082969665527344 doing MySQL queries and 0.075877904891968 doing PHP things.
