Time Before: 0.02828 seconds
Time After: 0.03660 seconds
Time Taken: 0.00832 seconds
Time Before: 0.03669 seconds
Time After: 0.03724 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03756 seconds
Time After: 0.03770 seconds
Time Before: 0.03844 seconds
Time After: 0.04033 seconds
Time Taken: 0.00190 seconds
Time Before: 0.03777 seconds
Time After: 0.04455 seconds
Time Taken: 0.00678 seconds
Time Before: 0.05358 seconds
Time After: 0.05389 seconds
Time Before: 0.05663 seconds
Time After: 0.05788 seconds
Time Before: 0.05281 seconds
Time After: 0.05806 seconds
Time Taken: 0.00525 seconds
Time Before: 0.09842 seconds
Time After: 0.09862 seconds
Time Before: 0.38502 seconds
Time After: 0.38627 seconds
Time Before: 0.39677 seconds
Time After: 0.39697 seconds
Time Before: 0.39959 seconds
Time After: 0.40106 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100364', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.41818 seconds
Time After: 0.41845 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
