Time Before: 0.01696 seconds
Time After: 0.02405 seconds
Time Taken: 0.00708 seconds
Time Before: 0.02413 seconds
Time After: 0.02469 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02499 seconds
Time After: 0.02511 seconds
Time Before: 0.02586 seconds
Time After: 0.02834 seconds
Time Taken: 0.00248 seconds
Time Before: 0.02517 seconds
Time After: 0.03254 seconds
Time Taken: 0.00737 seconds
Time Before: 0.04010 seconds
Time After: 0.04049 seconds
Time Before: 0.04293 seconds
Time After: 0.04415 seconds
Time Before: 0.03939 seconds
Time After: 0.04435 seconds
Time Taken: 0.00496 seconds
Time Before: 0.06890 seconds
Time After: 0.06981 seconds
Time Taken: 0.00091 seconds
Time Before: 0.08522 seconds
Time After: 0.08651 seconds
End call of global.php: 0.089234828948975
Time Before: 0.09969 seconds
Time After: 0.09988 seconds
Time Before: 0.10265 seconds
Time After: 0.10414 seconds
SET lastactivity = 1777066063, location = '/forums/private.php?do=newpm&explain=1&u=100369', badlocation = 1
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.11936 seconds
Time After: 0.11980 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.11813688278198 seconds with 9 queries, spending 0.0090763568878174 doing MySQL queries and 0.10906052589417 doing PHP things.
