Time Before: 0.00154 seconds
Time After: 0.00229 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00238 seconds
Time After: 0.00292 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00319 seconds
Time After: 0.00330 seconds
Time Before: 0.00392 seconds
Time After: 0.00681 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00335 seconds
Time After: 0.01025 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01199 seconds
Time After: 0.01239 seconds
Time Before: 0.01484 seconds
Time After: 0.01611 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01142 seconds
Time After: 0.01630 seconds
Time Taken: 0.00487 seconds
Memory After: 2,261.703 KB
Time Before: 0.02115 seconds
Time After: 0.02129 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02322 seconds
Time After: 0.02448 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.02732 seconds
Time After: 0.02745 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02937 seconds
Time After: 0.03135 seconds
Time Taken: 0.00197 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100375' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04415 seconds
Time After: 0.04458 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
