Time Before: 0.00178 seconds
Time After: 0.00228 seconds
Time Before: 0.00235 seconds
Time After: 0.00296 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00320 seconds
Time After: 0.00331 seconds
Time Before: 0.00407 seconds
Time After: 0.00627 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00337 seconds
Time After: 0.00965 seconds
Time Taken: 0.00629 seconds
Time Before: 0.01165 seconds
Time After: 0.01216 seconds
Time Before: 0.01466 seconds
Time After: 0.01646 seconds
Time Taken: 0.00180 seconds
Time Before: 0.01097 seconds
Time After: 0.01665 seconds
Time Taken: 0.00568 seconds
Time Before: 0.02254 seconds
Time After: 0.02271 seconds
Time Before: 0.02485 seconds
Time After: 0.02617 seconds
Time Taken: 0.00132 seconds
Time Before: 0.02947 seconds
Time After: 0.02967 seconds
Time Before: 0.03175 seconds
Time After: 0.03319 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100404' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04548 seconds
Time After: 0.04576 seconds
