Time Before: 0.01763 seconds
Time After: 0.02208 seconds
Time Taken: 0.00445 seconds
Time Before: 0.02217 seconds
Time After: 0.02257 seconds
Time Before: 0.02285 seconds
Time After: 0.02298 seconds
Time Before: 0.02375 seconds
Time After: 0.02627 seconds
Time Taken: 0.00252 seconds
Time Before: 0.02304 seconds
Time After: 0.03035 seconds
Time Taken: 0.00731 seconds
Time Before: 0.03735 seconds
Time After: 0.03773 seconds
Time Before: 0.04042 seconds
Time After: 0.04158 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03674 seconds
Time After: 0.04175 seconds
Time Taken: 0.00501 seconds
Time Before: 0.07414 seconds
Time After: 0.07428 seconds
Time Before: 0.08867 seconds
Time After: 0.08991 seconds
Time Before: 0.09857 seconds
Time After: 0.09893 seconds
Time Before: 0.10190 seconds
Time After: 0.10463 seconds
Time Taken: 0.00273 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100409' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.12142 seconds
Time After: 0.12170 seconds
