Time Before: 0.00519 seconds
Time After: 0.00706 seconds
Time Taken: 0.00187 seconds
Time Before: 0.00716 seconds
Time After: 0.00760 seconds
Time Before: 0.00783 seconds
Time After: 0.00796 seconds
Time Before: 0.00868 seconds
Time After: 0.01134 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00803 seconds
Time After: 0.01568 seconds
Time Taken: 0.00765 seconds
Time Before: 0.02015 seconds
Time After: 0.02043 seconds
Time Before: 0.02239 seconds
Time After: 0.02361 seconds
Time Before: 0.01962 seconds
Time After: 0.02386 seconds
Time Taken: 0.00424 seconds
Time Before: 0.03414 seconds
Time After: 0.03431 seconds
Time Before: 0.03878 seconds
Time After: 0.04005 seconds
Time Before: 0.04631 seconds
Time After: 0.04661 seconds
Time Before: 0.04943 seconds
Time After: 0.05085 seconds
UPDATE session SET lastactivity = 1788935913, location = '/forums/private.php?do=newpm&explain=1&u=100414', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06907 seconds
Time After: 0.06936 seconds
