Time Before: 0.01399 seconds
Time After: 0.01965 seconds
Time Taken: 0.00566 seconds
Time Before: 0.01972 seconds
Time After: 0.02015 seconds
Time Before: 0.02040 seconds
Time After: 0.02053 seconds
Time Before: 0.02141 seconds
Time After: 0.02434 seconds
Time Taken: 0.00293 seconds
Time Before: 0.02059 seconds
Time After: 0.02945 seconds
Time Taken: 0.00886 seconds
Time Before: 0.03714 seconds
Time After: 0.03768 seconds
Time Taken: 0.00054 seconds
Time Before: 0.04114 seconds
Time After: 0.04253 seconds
Time Taken: 0.00138 seconds
Time Before: 0.03629 seconds
Time After: 0.04280 seconds
Time Taken: 0.00650 seconds
Time Before: 0.07936 seconds
Time After: 0.07952 seconds
Time Before: 0.18558 seconds
Time After: 0.18688 seconds
Time Taken: 0.00131 seconds
Time Before: 0.19968 seconds
Time After: 0.19987 seconds
Time Before: 0.20260 seconds
Time After: 0.20408 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100424', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.22168 seconds
Time After: 0.22194 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
