Time Before: 0.00148 seconds
Time After: 0.00205 seconds
Time Taken: 0.00057 seconds
Memory Before: 533.930 KB
Memory After: 559.047 KB
Time Before: 0.00212 seconds
Time After: 0.00262 seconds
Memory Before: 558.984 KB
Memory After: 559.992 KB
Time Before: 0.00291 seconds
Time After: 0.00309 seconds
Memory Before: 560.547 KB
Memory After: 561.070 KB
Time Before: 0.00409 seconds
Time After: 0.00724 seconds
Time Taken: 0.00315 seconds
Memory Before: 563.672 KB
Memory After: 564.594 KB
Time Before: 0.00319 seconds
Time After: 0.01239 seconds
Time Taken: 0.00920 seconds
Memory Before: 560.320 KB
Memory After: 1,641.344 KB
Memory Used: 1,081.023 KB
Time Before: 0.01489 seconds
Time After: 0.01528 seconds
Memory Before: 2,136.219 KB
Memory After: 2,136.836 KB
Time Before: 0.01784 seconds
Time After: 0.01915 seconds
Memory Before: 2,148.398 KB
Memory After: 2,148.258 KB
Time Before: 0.01413 seconds
Time After: 0.01940 seconds
Time Taken: 0.00527 seconds
Memory Before: 2,128.398 KB
Memory After: 2,261.281 KB
Time Before: 0.02604 seconds
Time After: 0.02621 seconds
Memory Before: 2,814.875 KB
Memory After: 2,815.391 KB
Time Before: 0.02817 seconds
Time After: 0.02939 seconds
Memory Before: 2,903.211 KB
Memory After: 2,903.805 KB
Time Before: 0.03225 seconds
Time After: 0.03247 seconds
Memory Before: 3,539.984 KB
Memory After: 3,540.414 KB
Time Before: 0.03443 seconds
Time After: 0.03589 seconds
Memory Before: 3,821.516 KB
Memory After: 3,823.203 KB
UPDATE session SET lastactivity = 1788975599, location = '/forums/private.php?do=newpm&explain=1&u=100429' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04850 seconds
Time After: 0.04879 seconds
Memory Before: 4,295.383 KB
Memory After: 4,295.609 KB
