Time Before: 0.00221 seconds
Time After: 0.00369 seconds
Time Before: 0.00377 seconds
Time After: 0.00422 seconds
Time Before: 0.00445 seconds
Time After: 0.00464 seconds
Time Before: 0.00581 seconds
Time After: 0.00830 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00469 seconds
Time After: 0.01186 seconds
Time Taken: 0.00717 seconds
Time Before: 0.01448 seconds
Time After: 0.01471 seconds
Time Before: 0.01711 seconds
Time After: 0.01834 seconds
Time Before: 0.01383 seconds
Time After: 0.01859 seconds
Time Taken: 0.00476 seconds
Time Before: 0.02983 seconds
Time After: 0.03006 seconds
Time Before: 0.03467 seconds
Time After: 0.03598 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.037859916687012
Time Before: 0.04013 seconds
Time After: 0.04031 seconds
Time Before: 0.04338 seconds
Time After: 0.04494 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=10043', badlocation = 1
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.06190 seconds
Time After: 0.06222 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.060919046401978 seconds with 9 queries, spending 0.0082001686096191 doing MySQL queries and 0.052718877792358 doing PHP things.
