Time Before: 0.00089 seconds
Time After: 0.00125 seconds
Time Before: 0.00129 seconds
Time After: 0.00173 seconds
Time Before: 0.00202 seconds
Time After: 0.00215 seconds
Time Before: 0.00306 seconds
Time After: 0.00548 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00222 seconds
Time After: 0.00922 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01116 seconds
Time After: 0.01155 seconds
Time Before: 0.01460 seconds
Time After: 0.01577 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01051 seconds
Time After: 0.01595 seconds
Time Taken: 0.00544 seconds
Time Before: 0.01932 seconds
Time After: 0.01944 seconds
Time Before: 0.02144 seconds
Time After: 0.02264 seconds
Time Before: 0.02552 seconds
Time After: 0.02568 seconds
Time Before: 0.02775 seconds
Time After: 0.02919 seconds
UPDATE session SET lastactivity = 1785316039, location = '/forums/private.php?do=newpm&explain=1&u=100430', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04145 seconds
Time After: 0.04175 seconds
