Time Before: 0.00149 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00304 seconds
Time Taken: 0.00103 seconds
Time Before: 0.00334 seconds
Time After: 0.00359 seconds
Time Before: 0.00436 seconds
Time After: 0.00692 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00365 seconds
Time After: 0.01030 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01212 seconds
Time After: 0.01248 seconds
Time Before: 0.01578 seconds
Time After: 0.01747 seconds
Time Taken: 0.00169 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01155 seconds
Time After: 0.01765 seconds
Time Taken: 0.00610 seconds
Memory After: 2,261.820 KB
Time Before: 0.02512 seconds
Time After: 0.02523 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02719 seconds
Time After: 0.02838 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.030056953430176
Time Before: 0.03133 seconds
Time After: 0.03146 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03345 seconds
Time After: 0.03491 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789078994, location = '/forums/private.php?do=newpm&explain=1&u=100439', badlocation = 1
Time Before: 0.04739 seconds
Time After: 0.04776 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.046360015869141 seconds with 9 queries, spending 0.0091724395751953 doing MySQL queries and 0.037187576293945 doing PHP things.
