Time Before: 0.03142 seconds
Time After: 0.04101 seconds
Time Taken: 0.00960 seconds
Time Before: 0.04113 seconds
Time After: 0.04159 seconds
Time Before: 0.04186 seconds
Time After: 0.04199 seconds
Time Before: 0.04287 seconds
Time After: 0.04510 seconds
Time Taken: 0.00222 seconds
Time Before: 0.04208 seconds
Time After: 0.04985 seconds
Time Taken: 0.00778 seconds
Time Before: 0.06207 seconds
Time After: 0.06247 seconds
Time Before: 0.06585 seconds
Time After: 0.06704 seconds
Time Taken: 0.00118 seconds
Time Before: 0.06139 seconds
Time After: 0.06725 seconds
Time Taken: 0.00586 seconds
Time Before: 0.12630 seconds
Time After: 0.12645 seconds
Time Before: 0.14880 seconds
Time After: 0.15002 seconds
Time Before: 0.15876 seconds
Time After: 0.15892 seconds
Time Before: 0.16165 seconds
Time After: 0.16315 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100440', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.18131 seconds
Time After: 0.18154 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
