Time Before: 0.02406 seconds
Time After: 0.03170 seconds
Time Taken: 0.00764 seconds
Time Before: 0.03183 seconds
Time After: 0.03226 seconds
Time Before: 0.03252 seconds
Time After: 0.03266 seconds
Time Before: 0.03349 seconds
Time After: 0.03572 seconds
Time Taken: 0.00223 seconds
Time Before: 0.03272 seconds
Time After: 0.03947 seconds
Time Taken: 0.00675 seconds
Time Before: 0.05165 seconds
Time After: 0.05206 seconds
Time Before: 0.05540 seconds
Time After: 0.05680 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05086 seconds
Time After: 0.05699 seconds
Time Taken: 0.00613 seconds
Memory After: 2,261.820 KB
Time Before: 0.09148 seconds
Time After: 0.09215 seconds
Time Taken: 0.00067 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.40330 seconds
Time After: 0.40467 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.41447 seconds
Time After: 0.41464 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.41695 seconds
Time After: 0.41847 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788874130, location = '/forums/private.php?do=newpm&explain=1&u=100445' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.43962 seconds
Time After: 0.43989 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
