Time Before: 0.00153 seconds
Time After: 0.00193 seconds
Time Before: 0.00201 seconds
Time After: 0.00261 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00285 seconds
Time After: 0.00303 seconds
Time Before: 0.00365 seconds
Time After: 0.00613 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00307 seconds
Time After: 0.00952 seconds
Time Taken: 0.00644 seconds
Time Before: 0.01197 seconds
Time After: 0.01240 seconds
Time Before: 0.01406 seconds
Time After: 0.01527 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01117 seconds
Time After: 0.01552 seconds
Time Taken: 0.00434 seconds
Memory After: 2,261.820 KB
Time Before: 0.02224 seconds
Time After: 0.02239 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02408 seconds
Time After: 0.02530 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.026987791061401
Time Before: 0.02851 seconds
Time After: 0.02871 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03082 seconds
Time After: 0.03229 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789115551, location = '/forums/private.php?do=newpm&explain=1&u=100465'
Time Before: 0.04488 seconds
Time After: 0.04537 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.043948888778687 seconds with 9 queries, spending 0.0084128379821777 doing MySQL queries and 0.035536050796509 doing PHP things.
