Time Before: 0.01070 seconds
Time After: 0.01239 seconds
Time Taken: 0.00169 seconds
Time Before: 0.01249 seconds
Time After: 0.01299 seconds
Time Before: 0.01332 seconds
Time After: 0.01348 seconds
Time Before: 0.01434 seconds
Time After: 0.01676 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01357 seconds
Time After: 0.02130 seconds
Time Taken: 0.00773 seconds
Time Before: 0.02586 seconds
Time After: 0.02659 seconds
Time Taken: 0.00073 seconds
Time Before: 0.02823 seconds
Time After: 0.03056 seconds
Time Taken: 0.00232 seconds
Time Before: 0.02467 seconds
Time After: 0.03079 seconds
Time Taken: 0.00612 seconds
Time Before: 0.05083 seconds
Time After: 0.05102 seconds
Time Before: 0.05789 seconds
Time After: 0.05917 seconds
Time Before: 0.06443 seconds
Time After: 0.06470 seconds
Time Before: 0.06744 seconds
Time After: 0.06891 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100488', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.08746 seconds
Time After: 0.08772 seconds
