Time Before: 0.00221 seconds
Time After: 0.00288 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00295 seconds
Time After: 0.00333 seconds
Time Before: 0.00357 seconds
Time After: 0.00373 seconds
Time Before: 0.00453 seconds
Time After: 0.00652 seconds
Time Taken: 0.00199 seconds
Time Before: 0.00377 seconds
Time After: 0.01160 seconds
Time Taken: 0.00782 seconds
Time Before: 0.01482 seconds
Time After: 0.01535 seconds
Time Before: 0.01844 seconds
Time After: 0.01967 seconds
Time Before: 0.01411 seconds
Time After: 0.01995 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02751 seconds
Time After: 0.02764 seconds
Time Before: 0.03020 seconds
Time After: 0.03147 seconds
Time Before: 0.03510 seconds
Time After: 0.03543 seconds
Time Before: 0.03751 seconds
Time After: 0.03900 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100505' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05163 seconds
Time After: 0.05195 seconds
