Time Before: 0.03141 seconds
Time After: 0.03830 seconds
Time Taken: 0.00688 seconds
Time Before: 0.03841 seconds
Time After: 0.03913 seconds
Time Taken: 0.00073 seconds
Time Before: 0.03939 seconds
Time After: 0.03954 seconds
Time Before: 0.04034 seconds
Time After: 0.04556 seconds
Time Taken: 0.00522 seconds
Time Before: 0.03962 seconds
Time After: 0.05010 seconds
Time Taken: 0.01048 seconds
Time Before: 0.05972 seconds
Time After: 0.06018 seconds
Time Before: 0.06292 seconds
Time After: 0.06417 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05894 seconds
Time After: 0.06442 seconds
Time Taken: 0.00548 seconds
Memory After: 2,261.820 KB
Time Before: 0.11108 seconds
Time After: 0.11123 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.13294 seconds
Time After: 0.13424 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.15185 seconds
Time After: 0.15209 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.15538 seconds
Time After: 0.15846 seconds
Time Taken: 0.00308 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788961167, location = '/forums/private.php?do=newpm&explain=1&u=100506' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.17958 seconds
Time After: 0.18022 seconds
Time Taken: 0.00065 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
