Time Before: 0.01645 seconds
Time After: 0.02384 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02397 seconds
Time After: 0.02452 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02476 seconds
Time After: 0.02496 seconds
Time Before: 0.02574 seconds
Time After: 0.02769 seconds
Time Taken: 0.00196 seconds
Time Before: 0.02503 seconds
Time After: 0.03265 seconds
Time Taken: 0.00761 seconds
Time Before: 0.03885 seconds
Time After: 0.03926 seconds
Time Before: 0.04073 seconds
Time After: 0.04189 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03810 seconds
Time After: 0.04210 seconds
Time Taken: 0.00400 seconds
Memory After: 2,261.820 KB
Time Before: 0.06244 seconds
Time After: 0.06265 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.27278 seconds
Time After: 0.27410 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.28163 seconds
Time After: 0.28177 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.28427 seconds
Time After: 0.28584 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789107521, location = '/forums/private.php?do=newpm&explain=1&u=100519', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.30681 seconds
Time After: 0.30711 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
