Time Before: 0.00672 seconds
Time After: 0.01308 seconds
Time Taken: 0.00636 seconds
Time Before: 0.01318 seconds
Time After: 0.01361 seconds
Time Before: 0.01388 seconds
Time After: 0.01403 seconds
Time Before: 0.01491 seconds
Time After: 0.01786 seconds
Time Taken: 0.00296 seconds
Time Before: 0.01410 seconds
Time After: 0.02159 seconds
Time Taken: 0.00749 seconds
Time Before: 0.02663 seconds
Time After: 0.02707 seconds
Time Before: 0.03001 seconds
Time After: 0.03120 seconds
Time Before: 0.02587 seconds
Time After: 0.03141 seconds
Time Taken: 0.00554 seconds
Time Before: 0.04642 seconds
Time After: 0.04660 seconds
Time Before: 0.05837 seconds
Time After: 0.05961 seconds
Time Before: 0.07062 seconds
Time After: 0.07077 seconds
Time Before: 0.07321 seconds
Time After: 0.07516 seconds
Time Taken: 0.00196 seconds
UPDATE session SET lastactivity = 1789043247, location = '/forums/private.php?do=newpm&explain=1&u=100533' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.09375 seconds
Time After: 0.09414 seconds
