Time Before: 0.00196 seconds
Time After: 0.00297 seconds
Time Taken: 0.00101 seconds
Time Before: 0.00306 seconds
Time After: 0.00348 seconds
Time Before: 0.00372 seconds
Time After: 0.00385 seconds
Time Before: 0.00476 seconds
Time After: 0.00697 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00393 seconds
Time After: 0.01038 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01217 seconds
Time After: 0.01237 seconds
Time Before: 0.01558 seconds
Time After: 0.01679 seconds
Time Before: 0.01156 seconds
Time After: 0.01697 seconds
Time Taken: 0.00541 seconds
Time Before: 0.02207 seconds
Time After: 0.02220 seconds
Time Before: 0.02403 seconds
Time After: 0.02522 seconds
Time Before: 0.02823 seconds
Time After: 0.02838 seconds
Time Before: 0.03057 seconds
Time After: 0.03200 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100535', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04614 seconds
Time After: 0.04640 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
