Time Before: 0.00138 seconds
Time After: 0.00184 seconds
Time Before: 0.00190 seconds
Time After: 0.00225 seconds
Time Before: 0.00244 seconds
Time After: 0.00256 seconds
Time Before: 0.00327 seconds
Time After: 0.00574 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00261 seconds
Time After: 0.00988 seconds
Time Taken: 0.00727 seconds
Time Before: 0.01161 seconds
Time After: 0.01187 seconds
Time Before: 0.01493 seconds
Time After: 0.01653 seconds
Time Taken: 0.00159 seconds
Time Before: 0.01095 seconds
Time After: 0.01670 seconds
Time Taken: 0.00574 seconds
Time Before: 0.02405 seconds
Time After: 0.02420 seconds
Time Before: 0.02638 seconds
Time After: 0.02760 seconds
Time Before: 0.03028 seconds
Time After: 0.03040 seconds
Time Before: 0.03243 seconds
Time After: 0.03389 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100545' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04667 seconds
Time After: 0.04688 seconds
