Time Before: 0.00138 seconds
Time After: 0.00191 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00198 seconds
Time After: 0.00243 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00264 seconds
Time After: 0.00279 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00353 seconds
Time After: 0.00621 seconds
Time Taken: 0.00267 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00284 seconds
Time After: 0.01029 seconds
Time Taken: 0.00746 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01212 seconds
Time After: 0.01255 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01536 seconds
Time After: 0.01664 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01151 seconds
Time After: 0.01685 seconds
Time Taken: 0.00535 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02457 seconds
Time After: 0.02472 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02737 seconds
Time After: 0.02865 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.03255 seconds
Time After: 0.03272 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03559 seconds
Time After: 0.03709 seconds
Time Taken: 0.00150 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100548' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.05500 seconds
Time After: 0.05529 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
