Time Before: 0.00175 seconds
Time After: 0.00222 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00232 seconds
Time After: 0.00280 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00312 seconds
Time After: 0.00327 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00420 seconds
Time After: 0.00727 seconds
Time Taken: 0.00307 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00337 seconds
Time After: 0.01305 seconds
Time Taken: 0.00968 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01561 seconds
Time After: 0.01601 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01923 seconds
Time After: 0.02039 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01474 seconds
Time After: 0.02064 seconds
Time Taken: 0.00590 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02821 seconds
Time After: 0.02835 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.03068 seconds
Time After: 0.03294 seconds
Time Taken: 0.00226 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.03770 seconds
Time After: 0.03789 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.04096 seconds
Time After: 0.04246 seconds
Time Taken: 0.00150 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100549' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05975 seconds
Time After: 0.06001 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
