Time Before: 0.00441 seconds
Time After: 0.00586 seconds
Time Before: 0.00594 seconds
Time After: 0.00635 seconds
Time Before: 0.00659 seconds
Time After: 0.00674 seconds
Time Before: 0.00767 seconds
Time After: 0.00992 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00681 seconds
Time After: 0.01525 seconds
Time Taken: 0.00844 seconds
Time Before: 0.01790 seconds
Time After: 0.01833 seconds
Time Before: 0.02168 seconds
Time After: 0.02287 seconds
Time Before: 0.01710 seconds
Time After: 0.02309 seconds
Time Taken: 0.00599 seconds
Time Before: 0.03678 seconds
Time After: 0.03692 seconds
Time Before: 0.04255 seconds
Time After: 0.04380 seconds
Time Before: 0.05055 seconds
Time After: 0.05070 seconds
Time Before: 0.05286 seconds
Time After: 0.05431 seconds
UPDATE session SET lastactivity = 1785339889, location = '/forums/private.php?do=newpm&explain=1&u=100559' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.07256 seconds
Time After: 0.07307 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
