Time Before: 0.01425 seconds
Time After: 0.01903 seconds
Time Taken: 0.00479 seconds
Time Before: 0.01912 seconds
Time After: 0.02008 seconds
Time Taken: 0.00096 seconds
Time Before: 0.02040 seconds
Time After: 0.02054 seconds
Time Before: 0.02148 seconds
Time After: 0.02361 seconds
Time Taken: 0.00213 seconds
Time Before: 0.02062 seconds
Time After: 0.02762 seconds
Time Taken: 0.00700 seconds
Memory After: 1,642.430 KB
Memory Used: 1,081.023 KB
Time Before: 0.03300 seconds
Time After: 0.03334 seconds
Memory Before: 2,137.359 KB
Memory After: 2,137.977 KB
Time Before: 0.03595 seconds
Time After: 0.03715 seconds
Memory Before: 2,149.539 KB
Memory After: 2,149.398 KB
Time Before: 0.03233 seconds
Time After: 0.03735 seconds
Time Taken: 0.00502 seconds
Memory Before: 2,129.539 KB
Memory After: 2,262.438 KB
Memory Used: 132.898 KB
Time Before: 0.05880 seconds
Time After: 0.05897 seconds
Memory Before: 2,815.945 KB
Memory After: 2,816.461 KB
Time Before: 0.06875 seconds
Time After: 0.06997 seconds
Memory Before: 2,904.164 KB
Memory After: 2,904.758 KB
Time Before: 0.07635 seconds
Time After: 0.07649 seconds
Memory Before: 3,540.984 KB
Memory After: 3,541.414 KB
Time Before: 0.07898 seconds
Time After: 0.08044 seconds
Memory Before: 3,822.563 KB
Memory After: 3,824.250 KB
UPDATE session SET lastactivity = 1785310968, location = '/forums/private.php?do=newpm&explain=1&u=100562' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.10123 seconds
Time After: 0.10153 seconds
Memory Before: 4,288.273 KB
Memory After: 4,288.500 KB
