Time Before: 0.00364 seconds
Time After: 0.00431 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00438 seconds
Time After: 0.00526 seconds
Time Taken: 0.00088 seconds
Time Before: 0.00553 seconds
Time After: 0.00590 seconds
Time Before: 0.00690 seconds
Time After: 0.01089 seconds
Time Taken: 0.00399 seconds
Time Before: 0.00598 seconds
Time After: 0.01572 seconds
Time Taken: 0.00974 seconds
Time Before: 0.01939 seconds
Time After: 0.01980 seconds
Time Before: 0.02238 seconds
Time After: 0.02360 seconds
Time Before: 0.01874 seconds
Time After: 0.02388 seconds
Time Taken: 0.00514 seconds
Time Before: 0.04101 seconds
Time After: 0.04119 seconds
Time Before: 0.04826 seconds
Time After: 0.04953 seconds
Time Before: 0.05485 seconds
Time After: 0.05502 seconds
Time Before: 0.05790 seconds
Time After: 0.05941 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100570', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.07750 seconds
Time After: 0.07783 seconds
