Time Before: 0.00928 seconds
Time After: 0.01177 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01188 seconds
Time After: 0.01230 seconds
Time Before: 0.01255 seconds
Time After: 0.01268 seconds
Time Before: 0.01352 seconds
Time After: 0.01611 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01273 seconds
Time After: 0.02007 seconds
Time Taken: 0.00734 seconds
Time Before: 0.02347 seconds
Time After: 0.02392 seconds
Time Before: 0.02707 seconds
Time After: 0.02853 seconds
Time Before: 0.02276 seconds
Time After: 0.02881 seconds
Time Taken: 0.00605 seconds
Time Before: 0.04491 seconds
Time After: 0.04504 seconds
Time Before: 0.05399 seconds
Time After: 0.05528 seconds
End call of global.php: 0.057636022567749
Time Before: 0.06284 seconds
Time After: 0.06301 seconds
Time Before: 0.06519 seconds
Time After: 0.06674 seconds
Time Taken: 0.00155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100573', badlocation = 1
Time Before: 0.08179 seconds
Time After: 0.08210 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.080564975738525 seconds with 9 queries, spending 0.0084900856018066 doing MySQL queries and 0.072074890136719 doing PHP things.
