Time Before: 0.02110 seconds
Time After: 0.02928 seconds
Time Taken: 0.00818 seconds
Time Before: 0.02939 seconds
Time After: 0.02986 seconds
Time Before: 0.03017 seconds
Time After: 0.03043 seconds
Time Before: 0.03129 seconds
Time After: 0.03320 seconds
Time Taken: 0.00191 seconds
Time Before: 0.03051 seconds
Time After: 0.03869 seconds
Time Before: 0.04766 seconds
Time After: 0.04809 seconds
Time Before: 0.05063 seconds
Time After: 0.05184 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04695 seconds
Time After: 0.05210 seconds
Time Taken: 0.00515 seconds
Memory After: 2,261.703 KB
Time Before: 0.08380 seconds
Time After: 0.08396 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10516 seconds
Time After: 0.10646 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11659 seconds
Time After: 0.11679 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.11970 seconds
Time After: 0.12117 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100583' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.14085 seconds
Time After: 0.14120 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
