Time Before: 0.02940 seconds
Time After: 0.03740 seconds
Time Taken: 0.00800 seconds
Time Before: 0.03752 seconds
Time After: 0.03793 seconds
Time Before: 0.03815 seconds
Time After: 0.03826 seconds
Time Before: 0.03909 seconds
Time After: 0.04158 seconds
Time Taken: 0.00249 seconds
Time Before: 0.03833 seconds
Time After: 0.04623 seconds
Time Taken: 0.00790 seconds
Time Before: 0.05457 seconds
Time After: 0.05502 seconds
Time Before: 0.05751 seconds
Time After: 0.05869 seconds
Time Before: 0.05378 seconds
Time After: 0.05892 seconds
Time Taken: 0.00514 seconds
Time Before: 0.08922 seconds
Time After: 0.08938 seconds
Time Before: 0.11074 seconds
Time After: 0.11199 seconds
Time Before: 0.12091 seconds
Time After: 0.12105 seconds
Time Before: 0.12412 seconds
Time After: 0.12558 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100604', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.14468 seconds
Time After: 0.14497 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
