Time Before: 0.00158 seconds
Time After: 0.00211 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00222 seconds
Time After: 0.00284 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00310 seconds
Time After: 0.00328 seconds
Time Before: 0.00393 seconds
Time After: 0.00670 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00333 seconds
Time After: 0.01012 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01180 seconds
Time After: 0.01224 seconds
Time Before: 0.01476 seconds
Time After: 0.01602 seconds
Time Before: 0.01125 seconds
Time After: 0.01620 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02170 seconds
Time After: 0.02212 seconds
Time Before: 0.02440 seconds
Time After: 0.02565 seconds
End call of global.php: 0.027805089950562
Time Before: 0.02903 seconds
Time After: 0.02921 seconds
Time Before: 0.03166 seconds
Time After: 0.03361 seconds
Time Taken: 0.00195 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100607', badlocation = 1
Time Before: 0.04832 seconds
Time After: 0.04867 seconds
Page generated in 0.047374963760376 seconds with 9 queries, spending 0.0094194412231445 doing MySQL queries and 0.037955522537231 doing PHP things.
