Time Before: 0.00177 seconds
Time After: 0.00266 seconds
Time Taken: 0.00090 seconds
Time Before: 0.00276 seconds
Time After: 0.00341 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00376 seconds
Time After: 0.00416 seconds
Time Before: 0.00499 seconds
Time After: 0.00838 seconds
Time Taken: 0.00339 seconds
Time Before: 0.00423 seconds
Time After: 0.01180 seconds
Time Taken: 0.00757 seconds
Time Before: 0.01358 seconds
Time After: 0.01405 seconds
Time Before: 0.01654 seconds
Time After: 0.01799 seconds
Time Before: 0.01292 seconds
Time After: 0.01817 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02304 seconds
Time After: 0.02325 seconds
Time Before: 0.02516 seconds
Time After: 0.02638 seconds
Time Before: 0.02976 seconds
Time After: 0.02996 seconds
Time Before: 0.03203 seconds
Time After: 0.03347 seconds
UPDATE session SET lastactivity = 1785412762, location = '/forums/private.php?do=newpm&explain=1&u=100610', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04731 seconds
Time After: 0.04762 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
