Time Before: 0.01600 seconds
Time After: 0.02328 seconds
Time Taken: 0.00729 seconds
Time Before: 0.02337 seconds
Time After: 0.02390 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02420 seconds
Time After: 0.02433 seconds
Time Before: 0.02505 seconds
Time After: 0.02737 seconds
Time Taken: 0.00233 seconds
Time Before: 0.02438 seconds
Time After: 0.03155 seconds
Time Taken: 0.00717 seconds
Time Before: 0.04015 seconds
Time After: 0.04050 seconds
Time Before: 0.04311 seconds
Time After: 0.04434 seconds
Time Before: 0.03951 seconds
Time After: 0.04456 seconds
Time Taken: 0.00506 seconds
Time Before: 0.07126 seconds
Time After: 0.07144 seconds
Time Before: 0.08740 seconds
Time After: 0.08862 seconds
Time Before: 0.09649 seconds
Time After: 0.09669 seconds
Time Before: 0.09902 seconds
Time After: 0.10048 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100617' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12023 seconds
Time After: 0.12056 seconds
