Time Before: 0.02387 seconds
Time After: 0.03263 seconds
Time Taken: 0.00876 seconds
Time Before: 0.03274 seconds
Time After: 0.03325 seconds
Time Before: 0.03353 seconds
Time After: 0.03368 seconds
Time Before: 0.03455 seconds
Time After: 0.03754 seconds
Time Taken: 0.00299 seconds
Time Before: 0.03379 seconds
Time After: 0.04229 seconds
Time Taken: 0.00851 seconds
Time Before: 0.05142 seconds
Time After: 0.05184 seconds
Time Before: 0.05416 seconds
Time After: 0.05591 seconds
Time Taken: 0.00175 seconds
Time Before: 0.05082 seconds
Time After: 0.05615 seconds
Time Taken: 0.00533 seconds
Time Before: 0.08727 seconds
Time After: 0.08750 seconds
Time Before: 0.10456 seconds
Time After: 0.10582 seconds
Time Before: 0.11373 seconds
Time After: 0.11394 seconds
Time Before: 0.11705 seconds
Time After: 0.11851 seconds
UPDATE session SET lastactivity = 1776667214, location = '/forums/private.php?do=newpm&explain=1&u=100635' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.14069 seconds
Time After: 0.14097 seconds
