Time Before: 0.00165 seconds
Time After: 0.00228 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00236 seconds
Time After: 0.00275 seconds
Time Before: 0.00295 seconds
Time After: 0.00308 seconds
Time Before: 0.00385 seconds
Time After: 0.00638 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00316 seconds
Time After: 0.01090 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01280 seconds
Time After: 0.01334 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01501 seconds
Time After: 0.01668 seconds
Time Taken: 0.00167 seconds
Time Before: 0.01215 seconds
Time After: 0.01697 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02368 seconds
Time After: 0.02381 seconds
Time Before: 0.02591 seconds
Time After: 0.02717 seconds
Time Before: 0.03070 seconds
Time After: 0.03085 seconds
Time Before: 0.03393 seconds
Time After: 0.03542 seconds
UPDATE session SET lastactivity = 1785429616, location = '/forums/private.php?do=newpm&explain=1&u=100645' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04919 seconds
Time After: 0.04947 seconds
