Time Before: 0.00154 seconds
Time After: 0.00231 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00239 seconds
Time After: 0.00277 seconds
Time Before: 0.00302 seconds
Time After: 0.00317 seconds
Time Before: 0.00389 seconds
Time After: 0.00654 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00322 seconds
Time After: 0.01108 seconds
Time Taken: 0.00787 seconds
Time Before: 0.01360 seconds
Time After: 0.01407 seconds
Time Before: 0.01672 seconds
Time After: 0.01799 seconds
Time Before: 0.01283 seconds
Time After: 0.01817 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02329 seconds
Time After: 0.02349 seconds
Time Before: 0.02554 seconds
Time After: 0.02680 seconds
Time Before: 0.02965 seconds
Time After: 0.02980 seconds
Time Before: 0.03179 seconds
Time After: 0.03326 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100647', badlocation = 1 WHERE sessionhash = '498d073752497ccaba409783e9267bef'
Time Before: 0.04583 seconds
Time After: 0.04610 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
