Time Before: 0.00228 seconds
Time After: 0.00277 seconds
Time Before: 0.00284 seconds
Time After: 0.00325 seconds
Time Before: 0.00344 seconds
Time After: 0.00357 seconds
Time Before: 0.00424 seconds
Time After: 0.00707 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00362 seconds
Time After: 0.01053 seconds
Time Taken: 0.00691 seconds
Time Before: 0.01241 seconds
Time After: 0.01262 seconds
Time Before: 0.01548 seconds
Time After: 0.01683 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01180 seconds
Time After: 0.01701 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02213 seconds
Time After: 0.02227 seconds
Time Before: 0.02457 seconds
Time After: 0.02588 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02941 seconds
Time After: 0.02962 seconds
Time Before: 0.03181 seconds
Time After: 0.03330 seconds
UPDATE session SET lastactivity = 1782939874, location = '/forums/private.php?do=newpm&explain=1&u=100649' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04574 seconds
Time After: 0.04604 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
