Time Before: 0.01770 seconds
Time After: 0.02235 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02245 seconds
Time After: 0.02286 seconds
Time Before: 0.02309 seconds
Time After: 0.02323 seconds
Time Before: 0.02402 seconds
Time After: 0.02658 seconds
Time Taken: 0.00256 seconds
Time Before: 0.02329 seconds
Time After: 0.03052 seconds
Time Taken: 0.00724 seconds
Time Before: 0.03777 seconds
Time After: 0.03824 seconds
Time Before: 0.04081 seconds
Time After: 0.04204 seconds
Time Before: 0.03702 seconds
Time After: 0.04228 seconds
Time Taken: 0.00526 seconds
Time Before: 0.06270 seconds
Time After: 0.06288 seconds
Time Before: 0.07767 seconds
Time After: 0.07893 seconds
Time Before: 0.08955 seconds
Time After: 0.08977 seconds
Time Before: 0.09285 seconds
Time After: 0.09433 seconds
UPDATE session SET lastactivity = 1789109643, location = '/forums/private.php?do=newpm&explain=1&u=100654' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.11252 seconds
Time After: 0.11297 seconds
