Time Before: 0.00148 seconds
Time After: 0.00206 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00217 seconds
Time After: 0.00259 seconds
Time Before: 0.00283 seconds
Time After: 0.00296 seconds
Time Before: 0.00389 seconds
Time After: 0.00644 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00304 seconds
Time After: 0.00986 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01157 seconds
Time After: 0.01197 seconds
Time Before: 0.01484 seconds
Time After: 0.01610 seconds
Time Before: 0.01099 seconds
Time After: 0.01629 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02113 seconds
Time After: 0.02133 seconds
Time Before: 0.02304 seconds
Time After: 0.02428 seconds
Time Before: 0.02719 seconds
Time After: 0.02734 seconds
Time Before: 0.02944 seconds
Time After: 0.03086 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100666' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.04310 seconds
Time After: 0.04341 seconds
