Time Before: 0.00181 seconds
Time After: 0.00229 seconds
Time Before: 0.00236 seconds
Time After: 0.00272 seconds
Time Before: 0.00289 seconds
Time After: 0.00302 seconds
Time Before: 0.00359 seconds
Time After: 0.00586 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00307 seconds
Time After: 0.01075 seconds
Time Taken: 0.00767 seconds
Time Before: 0.01386 seconds
Time After: 0.01429 seconds
Time Before: 0.01656 seconds
Time After: 0.01783 seconds
Time Before: 0.01303 seconds
Time After: 0.01805 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02554 seconds
Time After: 0.02569 seconds
Time Before: 0.02734 seconds
Time After: 0.02860 seconds
Time Before: 0.03125 seconds
Time After: 0.03140 seconds
Time Before: 0.03352 seconds
Time After: 0.03495 seconds
UPDATE session SET lastactivity = 1788982085, location = '/forums/private.php?do=newpm&explain=1&u=100670' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05011 seconds
Time After: 0.05043 seconds
