Time Before: 0.03200 seconds
Time After: 0.04040 seconds
Time Taken: 0.00841 seconds
Time Before: 0.04053 seconds
Time After: 0.04097 seconds
Time Before: 0.04121 seconds
Time After: 0.04132 seconds
Time Before: 0.04208 seconds
Time After: 0.04485 seconds
Time Taken: 0.00277 seconds
Time Before: 0.04138 seconds
Time After: 0.04885 seconds
Time Taken: 0.00747 seconds
Time Before: 0.05602 seconds
Time After: 0.05640 seconds
Time Before: 0.05912 seconds
Time After: 0.06069 seconds
Time Taken: 0.00157 seconds
Time Before: 0.05534 seconds
Time After: 0.06089 seconds
Time Taken: 0.00555 seconds
Time Before: 0.10045 seconds
Time After: 0.10063 seconds
Time Before: 0.12477 seconds
Time After: 0.12600 seconds
Time Before: 0.13521 seconds
Time After: 0.13536 seconds
Time Before: 0.13788 seconds
Time After: 0.13939 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1776710445, location = '/forums/private.php?do=newpm&explain=1&u=100691', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.15661 seconds
Time After: 0.15692 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
