Time Before: 0.02925 seconds
Time After: 0.03715 seconds
Time Taken: 0.00790 seconds
Time Before: 0.03726 seconds
Time After: 0.03824 seconds
Time Taken: 0.00097 seconds
Time Before: 0.03855 seconds
Time After: 0.03869 seconds
Time Before: 0.03951 seconds
Time After: 0.04356 seconds
Time Taken: 0.00405 seconds
Time Before: 0.03875 seconds
Time After: 0.04807 seconds
Time Taken: 0.00933 seconds
Time Before: 0.05663 seconds
Time After: 0.05712 seconds
Time Before: 0.05891 seconds
Time After: 0.06013 seconds
Time Before: 0.05594 seconds
Time After: 0.06031 seconds
Time Taken: 0.00437 seconds
Memory After: 2,885.227 KB
Memory Used: 132.898 KB
Time Before: 0.09935 seconds
Time After: 0.09953 seconds
Memory Before: 3,438.344 KB
Memory After: 3,438.859 KB
Time Before: 0.12280 seconds
Time After: 0.12421 seconds
Memory Before: 3,526.039 KB
Memory After: 3,526.633 KB
Time Before: 0.13176 seconds
Time After: 0.13193 seconds
Memory Before: 4,163.938 KB
Memory After: 4,164.367 KB
Time Before: 0.13459 seconds
Time After: 0.13604 seconds
Memory Before: 4,445.500 KB
Memory After: 4,447.188 KB
UPDATE session SET lastactivity = 1785334496, location = '/forums/private.php?do=newpm&explain=1&u=100693' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.15352 seconds
Time After: 0.15378 seconds
Memory Before: 4,911.156 KB
Memory After: 4,911.383 KB
