Time Before: 0.00158 seconds
Time After: 0.00221 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00229 seconds
Time After: 0.00276 seconds
Time Before: 0.00295 seconds
Time After: 0.00307 seconds
Time Before: 0.00384 seconds
Time After: 0.00619 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00312 seconds
Time After: 0.00993 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01230 seconds
Time After: 0.01255 seconds
Time Before: 0.01565 seconds
Time After: 0.01690 seconds
Time Before: 0.01155 seconds
Time After: 0.01708 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02209 seconds
Time After: 0.02221 seconds
Time Before: 0.02420 seconds
Time After: 0.02541 seconds
End call of global.php: 0.027135133743286
Time Before: 0.02866 seconds
Time After: 0.02886 seconds
Time Before: 0.03117 seconds
Time After: 0.03294 seconds
Time Taken: 0.00177 seconds
SET lastactivity = 1789147655, location = '/forums/private.php?do=newpm&explain=1&u=100694'
Time Before: 0.04527 seconds
Time After: 0.04562 seconds
Page generated in 0.044373035430908 seconds with 9 queries, spending 0.0080785751342773 doing MySQL queries and 0.036294460296631 doing PHP things.
