Time Before: 0.00378 seconds
Time After: 0.00444 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00455 seconds
Time After: 0.00514 seconds
Time Taken: 0.00059 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00539 seconds
Time After: 0.00553 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00643 seconds
Time After: 0.00945 seconds
Time Taken: 0.00302 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00561 seconds
Time After: 0.01290 seconds
Time Taken: 0.00729 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01529 seconds
Time After: 0.01565 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01792 seconds
Time After: 0.01910 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01471 seconds
Time After: 0.01928 seconds
Time Taken: 0.00458 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02645 seconds
Time After: 0.02664 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03342 seconds
Time After: 0.03473 seconds
Time Taken: 0.00131 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.04254 seconds
Time After: 0.04277 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.04490 seconds
Time After: 0.04644 seconds
Time Taken: 0.00154 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772716160, location = '/forums/private.php?do=newpm&explain=1&u=100699' WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.05965 seconds
Time After: 0.05998 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
