Time Before: 0.03272 seconds
Time After: 0.04522 seconds
Time Taken: 0.01251 seconds
Time Before: 0.04534 seconds
Time After: 0.04576 seconds
Time Before: 0.04601 seconds
Time After: 0.04620 seconds
Time Before: 0.04700 seconds
Time After: 0.04945 seconds
Time Taken: 0.00245 seconds
Time Before: 0.04628 seconds
Time After: 0.05352 seconds
Time Taken: 0.00724 seconds
Time Before: 0.06514 seconds
Time After: 0.06546 seconds
Time Before: 0.06769 seconds
Time After: 0.06893 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06439 seconds
Time After: 0.06914 seconds
Time Taken: 0.00475 seconds
Memory After: 2,261.820 KB
Time Before: 0.11961 seconds
Time After: 0.11974 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.15259 seconds
Time After: 0.15385 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.16486 seconds
Time After: 0.16506 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.16758 seconds
Time After: 0.16910 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789043847, location = '/forums/private.php?do=newpm&explain=1&u=100702' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.19078 seconds
Time After: 0.19110 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
