Time Before: 0.01017 seconds
Time After: 0.01195 seconds
Time Taken: 0.00177 seconds
Time Before: 0.01206 seconds
Time After: 0.01257 seconds
Time Before: 0.01288 seconds
Time After: 0.01325 seconds
Time Before: 0.01434 seconds
Time After: 0.01722 seconds
Time Taken: 0.00288 seconds
Time Before: 0.01333 seconds
Time After: 0.02143 seconds
Time Taken: 0.00810 seconds
Time Before: 0.02596 seconds
Time After: 0.02640 seconds
Time Before: 0.02895 seconds
Time After: 0.03015 seconds
Time Before: 0.02500 seconds
Time After: 0.03036 seconds
Time Taken: 0.00536 seconds
Time Before: 0.04652 seconds
Time After: 0.04670 seconds
Time Before: 0.05363 seconds
Time After: 0.05498 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.057950973510742
Time Before: 0.06083 seconds
Time After: 0.06097 seconds
Time Before: 0.06328 seconds
Time After: 0.06477 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=100717', badlocation = 1
Time Before: 0.08075 seconds
Time After: 0.08111 seconds
Page generated in 0.079806089401245 seconds with 9 queries, spending 0.0088989734649658 doing MySQL queries and 0.070907115936279 doing PHP things.
