Time Before: 0.00233 seconds
Time After: 0.00342 seconds
Time Taken: 0.00109 seconds
Time Before: 0.00356 seconds
Time After: 0.00441 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00471 seconds
Time After: 0.00493 seconds
Time Before: 0.00566 seconds
Time After: 0.00822 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00498 seconds
Time After: 0.01314 seconds
Time Taken: 0.00817 seconds
Time Before: 0.01609 seconds
Time After: 0.01657 seconds
Time Before: 0.01964 seconds
Time After: 0.02088 seconds
Time Before: 0.01531 seconds
Time After: 0.02121 seconds
Time Taken: 0.00590 seconds
Time Before: 0.02980 seconds
Time After: 0.02993 seconds
Time Before: 0.03604 seconds
Time After: 0.03729 seconds
Time Before: 0.04298 seconds
Time After: 0.04313 seconds
Time Before: 0.04605 seconds
Time After: 0.04747 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100728', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06095 seconds
Time After: 0.06129 seconds
