Time Before: 0.01337 seconds
Time After: 0.01741 seconds
Time Taken: 0.00404 seconds
Time Before: 0.01751 seconds
Time After: 0.01793 seconds
Time Before: 0.01819 seconds
Time After: 0.01834 seconds
Time Before: 0.01907 seconds
Time After: 0.02199 seconds
Time Taken: 0.00291 seconds
Time Before: 0.01840 seconds
Time After: 0.02653 seconds
Time Taken: 0.00813 seconds
Time Before: 0.03440 seconds
Time After: 0.03481 seconds
Time Before: 0.03771 seconds
Time After: 0.03892 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03369 seconds
Time After: 0.03918 seconds
Time Taken: 0.00549 seconds
Memory After: 2,261.703 KB
Time Before: 0.06421 seconds
Time After: 0.06440 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07890 seconds
Time After: 0.08114 seconds
Time Taken: 0.00224 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.09028 seconds
Time After: 0.09047 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09311 seconds
Time After: 0.09460 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=100752' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11320 seconds
Time After: 0.11344 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
